crazycrak
Great to hear mines just a TBI 2.2L but im wanting to fix the car up and put a turbo 2.5L in it so I hope the lil 2.2 will run till then
Originally Posted By: 440Magnum
Pfft. Keep a timing belt on it (but even if it breaks its a free-wheeling engine), don't let it run low on coolant, and in another 200k miles you'll be looking for a way to kill it because you're so tired of it (actually, the car will fall apart around the drivetrain if you take care of it). Just ignore the wrist-pin rattle it will develop, too.
The Mopar 2.2/2.5 share main and conrod bearing dimensions with the old B-block v8 engines. Basically that means that the bottom end is almost as strong as a 426 Hemi (the crank IS as strong, but the inline block has a little less structure to support it than the deep-skirted cross-bolted v8 block did). Which is why people can screw the boost up to 20 PSI on turbo 2.5s and extract ~400 horsepower from them without too much grief as long as they keep the fuel mixture rich enough. At those levels, its the top end (head and head gasket) or the connecting rods that will give up first, or the pistons will burn if the mixture goes lean. Very rare to have bottom-end trouble on a 2.2/2.5.
