Daughter’s ‘15 Hyundai Elantra went over 220K miles last month.
We want interesting now!!!The Durango now has 195,000 miles. Will be posting more under valve cover pictures soon. This run of HPL only has 15k miles, so things may start to get interesting in about 10k miles.
amazingOil consumption got to 3 quarts per 5k miles but Restore and Protect completely eliminated.
Oh, it got too interesting...We want interesting now!!!![]()
2023 crosstrek 6mtThat's funny, same with my 14' outback on the right rear bearing right around 150k! Changed both while I was down there, other than that my list is pretty much the same as yours! Rock on subarus!
The A/C has been an issue with my parents 2018 Impreza. I think there was an A/C recall for certain year Subarus. Something to the effect of the dessicant system or compressor.I’m glad you guys have had good luck with your Subarus. Mine is a pre-detonating pile of bolts.
2023 crosstrek 6mt
Pings, has already needed a blower motor,burns 1qt every 5,000 miles, needs a passenger side front cv axle, the air conditioning sucks, and gas mileage has steadily declined in the past 3 months or so. I’m only at 58,000 miles.
This thing will be carvana’s problem soon.
Are the injectors sticking open? Run quart of any Atf in the tank and it will free them up.I just turned over 156,000 on my Cavalier. It needs the fuel injectors replaced again due to the design having a penchant for leaking.
No I sent out a second used set to the Fuel Injector Connection in Georgia. He spent a week trying to balance them with no luck. He sold me a new oem in the box set for $127 each vs the $280 each regular price. The bottom feeder design that GM only used for a few years allows the internal spring to rust. Not sure atf would fix this.Are the injectors sticking open? Run quart of any Atf in the tank and it will free them up.
I’ll give you $1500 for itI’m glad you guys have had good luck with your Subarus. Mine is a pre-detonating pile of bolts.
2023 crosstrek 6mt
Carvana says 16,000 lol.I’ll give you $1500 for it
Just kidding, sorry you’ve had a bad experience. Seems pretty unusual IMO, maybe your car was made on the day of a Purdue home game? Or even worse, the day after…
What has dealer said about the issue? I’d drive it hard enough to either set a CEL or blow it up while it’s under warranty…Carvana says 16,000 lol.
Seriously. It’s always pinged on 87 and my whole reason for buying the thing was because fuel wasn’t supposed to cost as much as my 350, 454, or idi diesel.
it won’t ping at all on 93 though.
