Originally Posted By: PontiacFan
Originally Posted By: daman
Originally Posted By: TimVipond
Does someone make longer extended oil change filters with better filtration than AMSOIL? Seems like AMSOIL leads here again, with XOM following.
Didn't someone here post a particle count test a wile back and the M1 lead the way?
https://bobistheoilguy.com/forums/posts/1251911/
The Mobil 1 Oil Filter did better than the Amsoil EaO Oil Filter, but the OCI was only run to 5000 miles.
My thinking is that if both oil filters were run out to maybe 10,000 miles, that the Mobil 1 Oil Filter would still do better.
It is quite clear that the Amsoil EaO Oil Filter is a waste of money if you are doing 5000 mile OCI's, the same thing could be said for the Mobil 1 Oil Filter for those doing 5000 mile OCI's.
Lets not forget, that Amsoil has a company making there oil filters, I believe it is Donaldson.
So, if we want to praise Amsoil Oil Filters then the praise should be directed at DONALDSON.
Thats it thanks, and yes only 5k but as stated it's efficiency @ a longer interval im sure would be as good...
and yes Donaldson
and yes Donaldson
