Thinnest Shear Stable xw-30 oil?
va
I remember how Quaker State touted their claims of a slight horsepower advantage when using their QS Horsepower and then the marketing went away when it became QS Ultimate Durability.
Under the same philosophy, I'd like to know of some xw-30 oils that are the thinnest @30w but that are resistant to sheer. Is QS Ultimate Durability the best option?
I was reading that Mobil 1 Advanced Fuel Economy 0w30 might be the best option.
Any ideas?
Thanks
If knowledge from the motorcycle world can be applied here, then you would actually want a conventional oil to resist shear. And you'd want a small "delta" between the multi-vis numbers (10W-30 would shear less than 0W-30).l
Originally Posted By: dx92beater
...claims of a slight horsepower advantage ...Under the same philosophy, I'd like to know of some xw-30 oils that are the thinnest..
looks like he's looking for that last .0001 HP available
....and that is the bottom line....maybe .001, maybe .01, maybe .1....but more than likely 1 or more.
It's just a hobby. As far as the rest of the posts I concur, but Dino probably isn't an option for that reason.
Wouldn't I generally be looking for the lowest cSt for starters and then take it from there as far as shear?
Regular Mobil 1 10W30 KV100 = 10.1 cSt, yet being a 10W30 rather than a 0W or 5W30 it uses less VII and is more shear stable.
For comparison
Regular Mobil 1 5W30, KV100 = 11.0 cSt
Pennzoil Platinum 5w30 and PP10W30, both have KV100 = 10.3 cSt
The PP xW30 is my second choice, as it's always on the thin end of the viscosity grade, and looks fairly shear stable in the used oil analysis I have seen.
Originally Posted By: Speak2Mountain
Some ppl may have a cow, but this
RedLine 0W30, KV100 = 11.7 cSt and HTHS = 3.2 cP, (nice Noack = 9% BTW)
That looks like a good oil, but definitely not the thinnest 30 grade around.
The regular Mobil 1 10W30 has a KV100 = 10.1 cSt and HTHS = 3.0 cP, so much thinner.
Regular old Mobil 1 or AFE? The vehicle is the EJ257 Turbo Forester XT. Everyone loves Rotella T6 5w-40 but that has to be cutting down HP quite a bit. Searching around, some guy reported an 11HP difference between RT6 and an x-w30. The vehicle is driven like an old person would drive it most of the time.
Some guy got here had a real nice UOA with Mobil 1 Advanced Fuel Economy 0w30 on this engine/trim as well. I think that regular Mobil 1 has a bad rep on these engines.
Check it out...
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2240969
Just curious and again having a good time. Thanks for the posts so far.
Look at the Mobil 1 web page. You want the lowest KV100 kinematic viscosity for the highest a HTHS dynamic viscosity. This reflects the lowest polymer VII load and the highest shear stability.
Regular Mobil 1 5W30, KV100 = 11.0 cSt, HTHS = 3.1 cP
Regular Mobil 1 10W30, KV100 = 10.1 cSt, HTHS = 3.0 cP
Mobil 1 Advanced Fuel Economy 0w30, KV100 = 10.9 cSt, HTHS = 3.0 cP
My first pick would be regular Mobil 1 10W30.
Sorry the AFE just doesn't do it for me.
Yep, I did. Thanks for picking this apart for me. I have walked away with something new.
