Originally Posted By: Gokhan
Originally Posted By: Pontual
Hear how quickier the engine turns with 5w30, as opposed to 15w40, specially for the initial 10 seconds. It gives a lot of spin while the pressure builds up. Even the tick-rattle of valve train is way more pronounced with the thinner oil.
Sound test comparison
https://www.youtube.com/watch?v=mKHwq1b3004
Start
Look at the graphs carefully. 5w30 (starts around 35 seconds) is a lot quieter. 15w40 (starts at the beginning of the video) is changing between ± 0.3, whereas 5w30 is changing between ± 0.2. Also, initial spikes are higher with 15w40 as well.
So, thicker oil is noisier and causes more wear at start-up as most people will say.
Moreover, the argument the first commenter made on YuTube is silly. If the engine is turning quicker with thinner oil, that means there is less friction. If there is less friction, there is less wear -- not more wear. Not to mention that a faster turning engine and an easier flowing, thinner oil will achieve the initial lubrication flow faster.
I mean the engine turns quicker because of less oil drag on thinner oil, the f.i. hjas to tune the idle down. Less drag do not mean less metal-to-metal friction. Metal to metal friction can't be avoided for the initial period (unless useing a solid lubricant dissolve in oil). If the engine turns quicker, there will be more wear. That's because old Anti-drain back valves aren't that good, they leak out a lot overnight. Also because the oil go down to the sump and every engine has to fill their filter - after - startup and send the oil throght plumbing to the head and various part. Those take time and revolutions to accomplish ... Less revolutions, less wear.
Since pumps are positive displacement, the thicker oil will win the battle for protection (drag).
Take that into consideration over the discussion, if you will.
I WON!!! hahahahaha
