djb383
Hey thanks for all the info. I've always followed the manual on my past vehicles and will continue to do so, it's just takes a little 'getting used to' 20 weight. Again, thanks for the info and what a great site!
...runs great in a 5W-20 engine? All of them do. The 0W-30 Eurospec oils run TERRIBLE in 5W-20 engines, so don't tell people to use them in a 20 weight application! They are too thick at all reasonable operating temperatures. xW-20's have their own severe tests to pass, and other tests are irrelevant.quote:
Originally posted by androbot2084:
Name me one 5w20 engine oil that...
My Hyundai Accent GT 1.6 specs 5W20 SL with an option (availability or not) on 5W30 or 10W30. I got a pretty good stash of Pennzoil HM 10W30 for free recently, and I can't tell a lick of difference mileage-wise, feel of the engine, or performance.quote:
Experiment for yourself! Do a few UOA's and you'll find it probably doesn't matter what oil goes in most passenger vehicles.
Honda V6s are similar in that they will pump enough oil to hit the oil pump relief valve @3000 RPMs when warm (71 psi). And the pump displaces 15.4 gpm @6000RPM.quote:
Originally posted by Rodbuckler:
I think there must be some significant differences between the various 5W-20 spec'd engines as far as the volume of oil pumped is concerned...The crank mounted oil pump on the Modulars pumps a serious amount of oil...
I don't know how to give you an average, traffic is generally way to congested with my present commute. 2500 RPMs at 75 mph when I do get to set the cruise control. AC permanently on 9 months of the year. Thick oil testing was done when my commute was mostly rural and consistent, although widely varied.quote:
Originally posted by BlueWorld:
What's you're average rpm when you're driving?
With a 2K rpm average I get 23mpg in the Odyssey in mixed suburban use, AC permanently on.
This much is painfully apparent ..even here. I don't know about the mandate for a "0W" though.quote:
However there is still a delusion by the motoring public that 5w20 engine oil may have long term durability issues and the motorists that have these concerns may be using 5w30 motor oils instead of 5w20. Fully synthetic 0w30 motor oils have been developed as an alternative to 5w20 engine oils and provide motorists with the peace of mind of a 30 weight oil yet the cold weather capabilitities of a 0 weight oil. For these heavy weight oil enthusiasts a 0w30 offers far better protection than a comparable 5w30 oil.
