If you don't know when the bypass opens via factory info, how can you tell when it opens?
I got some data on my truck but haven't taken the time to noodle anything out.
RIght now: With the oil at 50F, oil pressure peaks at 88 psi @ 4500 rpm. Stays there past that but I didn't check past 5000. With the oil temp at 195F, it will max out at 76 psi at about 4500.
I can't get Ford specs for the 5.4L engine but Melling makes an OEM replacement. Using a standardized test oil (equivalent to 10W30), their pump delivers 38 psi @ 200F at 800 rpm and the bypass begins to open @ 69 psi @ 200F @ 2000 rpm. The pump is a Gerotor type, driven off the crankshaft snout.
Interestingly, Ford lists 75 psi @ 2000 rpm with a "warmed up" engine as "normal" oil pressure but does not directly specify the oil.
AERA lists 40-60 psi @ 2000 w/ "warmed up engine" as normal.
