Ok so we have dr Haas who convince us to use a thin oil
wich increases the oil flow att higher engine speeds but lowers the pressure at lower speeds- sound ok to me but..
What if my engine pops the valve at 1700 rpms and almost all
the time runs at that speed mostly towing, is then the reasoning ok?
Wouldnt it be better to have an oil thick enough to build pressure
and be on the verge for popping the valve?
Then ill get bot volume and pressure.
I understand dr H´s reasoning when it comes to high revving ferraris which doesent produce much of low speed torque anyway
and when working is at higher speeds but in my 5.9 l mopar
v8 wich usually is at highest possible gear and seldom see´s
anything higher than 2000 rpm´s?
