thickest 20 weight
georgia
I tried to search but came up empty, plus I know many of you have tons of knowledge you are itching to share....so, who has the thickest 5w20 conventional oil at this time ? I played with the idea of going to a 5w30 in my 20 weight spec'd cars just to experiment with smoothness/noise reduction etc. but I know the norm used to be that a 30 weight soon sheared down to a heavy 20 weight anyway (not sure if that is still true) so I would just be as well going with a heavy 20. Thanks for your insight on this one.
Also, one more question for cold starting, would a "conventional" 5w20 be close in terms of cold flow to a "synthetic" 5w30 (since synthetics supposedly thicken less than conventional) Or is the gap still pretty wide. when I say cold flow I mean something like 30F, not super cold. Thanks again.
Just use a 5w30
Just go with a synthetic 5w30 and you won't have to worry about shearing.
I don't see how people can tolerate the noise those 20 weights make.
Yep the heaviest 20wt, is a light 30wt.
Get a full synthetic ILSAC 5W30. The ILSAC grades are light 30wt oils compared to the heavy A3/B4 or HDEO 30 Wt oils.
Which 5W starts better? You have to look at the spec sheets. But 5w is a range, and some recent data I read here showed a 5w conventional closer to the top of the range and the full synthetic closer to the bottom (easier cold starting). But this was for below 0F, at 30F they should both be fine. Even a 10W will be fine above 0F.
There will be no audible difference in an engine between 5W-20 and 5w30. To say otherwise is absurd.
Color me absurd,then.
The ole 5.4 is MUCH quieter on 5w30 compared to the 5w20, particularly the timing chain.
I hope you're not betting your life on that statement. Viscosity plays a major role in lubrication and the sound (or absence of sound) is a testament to how well the engine is being lubricated.
While I don't agree with the second part about "how well the engine is being lubricated". There is definitely a difference in audibility of engine oils.
IME tends to agree with you ....
