No head scratching or "pencil whipping" is really required to determine this....
If the oil is thin enough to allow the engine to turn over and start easily, it's thin enough to use and won't result in abnormal wear....
German manufacturers use the standard CCS test temp as defined by the SAE J300 standard as their low temp limit for a particular SAE grade. This is a technically sound approach and will work with any engine....
SAE J300 Standard:
20w...-15C/+5F
15w...-20C/-4F
10w...-25C/-13F
5w....-30C/-22F
0w....-35C/-31F
In other words, your engine will start with a viscosity of 6000-7000 Centipoise, if the battery is in good shape and the engine is tuned up.
The only drawbacks will be sluggishness during the warmup phase and lower fuel efficiency at all times.
TS
SAE J300 Standard:
20w...-15C/+5F
15w...-20C/-4F
10w...-25C/-13F
5w....-30C/-22F
0w....-35C/-31F
TS
