The Volt and oil
Originally Posted By: Thermo1223
If that is the case why the need for a "mountain" mode to build up a battery charge to climb a long hill?
Everything I've read on the subject suggest the exact opposite of what you say.
I dont know,but hurry up and post something quick! look @ your post counter.
lol, that load of nonsense is about as bad as the pennzoil wax myth
Uhh, the top quality pennzoils (Ultra Helix) are made from wax
High quality Penn crude is paraffin.
I'm quite sure the engine will run on 5w30 or 5w20. Same stuff that runs other hybrid motors such as the prius. As far as the electric motor goes, I doubt it needs much maintenance.
I'm skeptical whether this vehicle will sell well, or even sell at all. Let me make a few points...
I'm sure the japanese will be introducing newer hybrid vehicles in the coming years. Not to mention, it's already been badge engineered, as opel and vauxhall each have their own version of the volt. It's priced at $41k. It'll take years to recoup the money you'll save on gas mileage with a volt, when you can simply buy a civic at an upfront lower price tag.
Seems like a vehicle for people who have more money than brains!
The U.S. gov't should be working hard at lowering fuel prices.Yet,that is not what they are doing.The gov't is doing just the opposite. Two dollar gasoline could help us get through this recession/depression.I like the idea of a turbo diesel car-No electric cars for me.
My guess is that the Chevy will have some sort of an engine oil change TIMER, that will go off at 6 months or 1 year intervals. It won't be running enough to beat the oil up in a years time I wouldn't think.
Also, I hope that there is a feature on the car that actually has the engine RUN more often if the engine hasn't been running enough (stale gas)..
"First, to release the gas nozzle inlet says Berman, the driver must touch a small gas release button on the driver’s door, hard to see, but right above the electric charging door release button.
After pressing the button there is a mandatory wait period signalled on the dashboard screen. During the wait, a vacuum pump decompresses the pressurized tank and pumps vapors into a “carbon canister.” This is a specialized system that normally keeps the gas tank sealed under pressure to prevent seepage of water and other factors that might lead to stale gas.
The car’s computer is always monitoring the gas situation. It knows how long its been since gas was last placed in as well as when the last time the engine was run. It also knows if you open the gas door but don’t actually fill up and even monitors the temperature of the gas to ensure it isnt “cooking.”
The car, of course needs to know all this because after a ceratin period of time the risk of gas going stale increases and the engine needs a cycling.
At that certain point, if fuel hasn’t been burned, the car will display a message encouraging the driver to drive beyond the EV range and let the generator go on. The driver can apparently ignore the warning but after two times the car will “take matters into its own hands,” writes Berman. This means the Volt will start its generator to burn some fuel, lubricate the mechnical parts, and “pressurize the engine system.”
After completing this “engine and fuel maintenance mode,” the gnerator shuts off allowing the car to go back into pure EV operation, until the next time some gas needs to be burned"
"Engine/Fuel Maintenance Mode will start the ICE every six weeks to lubricate the engine. Regardless of the age of the fuel in the tank.
Engine/Fuel Maintenance Mode will start the ICE or prompt the owner to drive beyond battery range when the average age of the gas in the tank exceeds a set parameter."
Whoah, a fuel/air bomb ready to go in the event of a crash.
Nice work.
Hopefully it will work.
My 2004 ECU which keeps track of how many hours the engine has been run went from 2780 to zero overnight. I now have 122,800 miles and 30 hours....
Vehicles like this are too complicated for me. I'll always look for the simpler way to do things. Even if it gets worst MPG (And I drive more than the average clown) because in the end the expensive toys will cost more.
Just my opinion.
I seen a Chevy Volt last night parked at local restaurant. It had regular Michigan License Plates, not Manufacturer Plates. Much nicer looking car when you see it in person, this one was Silver.
Nice work.
You don't really believe what you say I hope.
Nope, but a pressurised fuel tank may make crash scenese more interesting.
No doubt! Let's hope there is no chance of pressure sensor failures or system leakages
At that certain point, if fuel hasn’t been burned, the car will display a message encouraging the driver to drive beyond the EV range and let the generator go on. The driver can apparently ignore the warning but after two times the car will “take matters into its own hands,” writes Berman. This means the Volt will start its generator to burn some fuel, lubricate the mechnical parts, and “pressurize the engine system.”"
Interesting program. I never knew gas going 'stale' and/or water infiltration was such a concern in a sealed tank, to warrant the cost/installation of pressurization pumps and massive vapour canisters. Whatever the reasoning, I do know that it will guarantee that the Volt cannot be used as a 100% EV, and that petroleum MUST be burned at a minimum rate.
