The ultimate detail & maintenance with part numbers on Kohler V-Twin Nikki Carb Craftsman GT5000 6 H/L
The Woods of NY
I finally had a day off and wanted to give the Craftsman GT some attention and kinda "document" the part numbers in post 2 that will work with this 25 HP Kohler V-Twin CV730s, 1 barrel Nikki carburetor with accelerator pump / electronic fuel shut off solenoid, installed on a 917 series Craftsman GT5000 with a high low 6 speed manual.
I started with a full carburetor rebuild and used OEM Kohler parts. I had major sticker shock at $197 total for the two rebuild kits I needed. One had the float, bowl gasket, needle and misc other gaskets, the other kit was the accelerator pump gasket, spring, fuel delivery hoses, and a couple of the same gaskets at kit one. to note you can get them a little cheaper online.
After cleaning the carburetor thoroughly and reassembly, replaced the fuel filter, oil filter, air filter/pre cleaner, spark plugs and oil. I used VP Synthetic 10W30/SEA30. I did have a $19,99 Kohler Pro oil filter in my cart... Until I walked down the automotive aisle at Tractor supply. A quick google search later I had a much better made Purolator in an awesome red, for $5.99.
Last year I replaced both ignition coils and both head gaskets (Kohler OEM) can post part numbers if interested, with other misc other gaskets while I had it torn apart. Also did a manual transmission drain and fill... Twice. Replaced all belts, but did not replace the front tires that worn out because of a really bad alignment (now fixed) so while a TS they had the correct size Carlisle 16x6.50-8 turf pro tires. The tires were pretty reasonable priced imho at $59.99 each plus tax.
After all the maintenance, i followed up with a foam cannon hand wash, degreasing and a Chemical Guys Ceramic Hydro wax treatment. I learned my lesson with the tire wax and cutting the lawn so I skipped that this time.
The "icing on the cake" was to give all linkages throttle cables ect the dry lubrication treatment..
Here are the part numbers for some things, If any one needs anything specific please post and I will post the part numbers for you.
How many hours on it before the rebuild?
I posted another thread on the backstory of this GT when I picked it up a couple years ago but it was non-running for about 15 years because mice chewed the wires. When I picked it up the hour meter read about 25, and the owners confirmed they only used it “for a season or two“ and changed the oil once.
It was stored in an outside barn for those 15 years with gas in the tank, it looked like this the day I picked it up.
I would say the head gaskets blew as soon as I started using it regularly maybe around the 50 hour mark. Another gasket behind a plate on the front of the engine also gave out a couple hours later. I replaced the governor oil shaft seal also.
