The quality of mechanics that work on your vehicles and the quality of their work is a crapshoot now days.
I took my 2016 Honda CR-V for inspection on the 15th of last month, and the place I took it to is known for doing brake work (about 80 % of their business), and exhaust, inspections, and they also rent U-Haul trucks and trailers. I booked the apointment more than a month ahead, and told him that it would not need brakes, and I had taken apart the fronts and cleaned and lubed it and flushed brake fluid, but did not get around to taking apart the backs and wanted him to take them apart and clean and lube them. I also said I would supply new metal spring clips.
I put my torque-wrench in the front seat area with it set to the proper wheel lug torque of 80 Lb ft and a stubby extension and 19mm 6 point socket on it. And I asked him to please not overtighten the lug-nuts with the air gun but to please tighten them to the proper torque with my torque-wrench.
This brake shop has been in business in the Pittsburgh south hills area for as long as I can remember, and is in general thought of as doing top quality brake work.
Last week I stopped for a hogie at a local shop, and had to wait for it to be made. So I decided to pull the torque-wrench out of the spare tire area and check all the lugs to be sure none have come loose a little after 2 weeks of driving.
The first wheel I checked was the back drivers and ALL FIVE were very loose. It took more than a 1/4 turn for all 5 of them to get the touque-wrench to click. The other 3 wheels checked out OK with only one lug on the front passenger's moving a very small amount before the wrench clicked.
But all the lugs on one wheel being too loose is unexcusable, and downright dangerous. That wheel could of come off, and if it had who knows what could of happened. That could have resulted in a major accident. I was totally POed about this.
It was too late in the day to call that shop, but I called the next day. The mechanic that did the brakes answered, and was very apologetic. He did say that the other guy was the one who tighten the lugs. And that he might have been distracted when he was doing that job. But this really is totally unexcusable. A simple mistake like this could have cost somebody their life.
Just like a chain is only as strong as its weakest link, an auto repair place is only as good as its worst mechanic. And some of the clowns they have working at these places nowadays aren't worth their salt.
I know that if you want something done right you have to do it yourself but nowadays you can't even trust an inspection station to tighten the lug nuts properly when they inspect your vehicle.
I know there's some real nuts out there they're only concerned about getting enough money to buy their booze and that might be the kind of people that these places are hiring.
From now on if I ever get a car inspected I'm going to check the torque of the lug nuts before I drive it off their lot.
I had put 245 miles on my vehicle since inspection, and some of that was highway miles.
I had to pull the wheel on the opposite side and use that as a reference as to the proper size of the holes in the rim. And then pull off of the side that the lugs were loose and inspect those holes to be sure there was no damage. And also inspect the studs. Fortunately everything is OK and there is no extra wear on the wheel or studs.
Mechanics like this need a few lessons with a baseball bat in a dark alley. Some jobs that these nuts are doing can endanger people's lives if they are not done properly. And if they can't do the job properly they do not belong in that business.
Always been that way. Goes for a lot of machine shops too. Probably worse now.
Those reasons are why I started my own shop. We really do treat every car like it's our own. We have built a reputation so good that people come from different counties and wait for an opening. We are always 3-4 weeks booked but take people in with emergencys as we can. We are a very small shop and I would like to hire another tech (right now it is just me and my son) but i CANNOT find anyone with talent or quality to hire. So - we just keep moving best we can. Since retiring from GM last year to run this shop full time I have seen some shoddy work from other shops come thru often and shake my head.
I am the only person that touches any of my cars. I'll even remove the wheels from the car when getting new tires so they can't screw anything up on the car.
Ever since I started using the Tire Rack mobile installer, this has become so much easier. Used to have to tote the wheels/tires to the shop.
In my experience, lug nuts will be grossly overtightened by shops about 50% of the time, roughly correct the other 50%, and rarely ever left loose. Same has been true of the oil filter cap at the Toyota dealer. I always check lug tightness. One reason is that if they're ridiculously tight, I won't be able to change a tire on the road in case of a flat.
I don't have much faith in dealer techs. Seems many of them couldn't diagnose a flat tire and will say things that tell me they have no clue how things work or they assume I'm clueless. I have had good luck with a local chain for tires and repairs, my lug nuts are torqued correctly when I buy tires, and they don't play the upsell game. Took the wife's troublesome Equinox to them when the air injection kept setting a code that pointed to clogged air injection ports that I couldn't get rid of, and to my surprise, they arrived at the same conclusion. While they were in there found the exhaust manifold was cracked, so they took care of that too. Got it back and it was all fixed right.
I've resorted to using mobile mechanics so I can watch everything they do... I used to do all my own work, but after trying many shops/dealerships for many years, I realized most all mechanics seem to suck azz 👎
I'm sure there's good ones out there, they're just VERY FEW and FAR BETWEEN ☹️
Yeah I hear you. A local shop that had been good but the owner sold it to two employees. I thought oh they'll keep up the great service. I had rear brake work done. The lady at the front desk kept telling me that I needed new front pads and rotors due to the rotors having a little rust after my car sat. I changed them myself less than a year prior. I feel like people aren't going into the automotive industry and the few that do aren't mechanically inclined.
While I agree the quality of shops has declined, so has the quality of customers. Always ask yourself "am I a good customer?" because that makes a difference in your experience as well.
I run a small engine side business, and all of my clients are word of mouth and family/friends. Sometimes family/friends make the absolute worst customers. Some expect you to do work for free, and never seem to return calls/texts about additional parts inquiries, etc. I have a few customers that own commercial landscaping businesses, and they seem to get it. They drop off the machine "just fix it with what it needs, call me if it is over X amount" and are quick to respond to updates and questions about further work it might need.
Finding a good mechanic or shop has always been a crap shoot if you just walk into someplace. You have to do your research, not just roll into a shop and assume they will treat you well and know what they're doing. We've always had great mechanics because we're careful about who works on our cars, and we've lived in multiple cities. And when I say 'great' mechanic, I mean someone that not only is competent, but also tries to help you keep your vehicle on the road as economically as possible. Not just replace every last thing they can think of.
With the internet now you can use forums to help guide. In the last two cities my wife and I have lived I posted on a BMW forum looking for recommendations for a shop for my wife's vehicle, both shops that were recommended turned out to be great, we're grateful we found them. Did the same thing with my Mazda. Good shops and mechanics are out there, but you have to search them out. I'd also add that I generally stay away from chains ie Meinecki, Good Year, Firestone, etc. In fact I stay away from any shop that claims to service all vehicles that isn't say a tire ship. I look for places specific to the brands we have for mechanical work.
I also agree with the 'good customer' comments. having worked with the public before I know how ridiculous some people can be. Don't be one of those people.
