I think you are confused.
Jet engines were leaps forwards beyond biplanes. Glass cockpits were leaps forward as well. Both radically improved war fighting and airplane designs. FYI, fighter jets using jet engines, are far far far more fuel hungry than a biplane; so you have literally just destroyed your own argument. Thank you. I love it when internet folks kill their own argument. The world chose jet engines NOT for their irrelevant carbon offsets, but because it was the best device in spite of being fuel hungry.
Name any EV material improvement to war fighting or vehicles as it pertains to military usefulness. I won't hold my breath. EV are huge leaps backwards in terms of reliability, range, field repairs, durability, hauling power, cold-weather operation, and a host of other things important for military operations. They simply have ZERO ability to move heavy equipment, and in case you're not aware anything armored in heavy equipment and the military uses mostly armored vehicles.
Go look up the weight differences in an un-armored vs. armored Humvee or GMC Suburban. I'll get you started. A base M113 Humvee is around 6000 pounds. Add required armor and beefier engine/suspension/trans/brakes, tires, now you've basically doubled the weight to around 12,000 pounds. Suburban about 7500 pounds but armor and beefier truck comes in around 11,000 pounds. EV is not going to move that weight, not even factoring the massive battery that would need to be installed. Even if it could the battery would drain in 10 minutes.
Just forget serious armored vehicles like a Bradley fighting vehicle (30 tons), Stryker type (18 tons), or any tracked vehicle or tank like an M1 Abrams at 60 tons. EV won't even move these measured in tens of tons. Nor anything capable of passenger flight. It's all just this stupid fantasy religion that has a stranglehold on certain mentalities that kills critical thinking abilities.
If "save the environment" is the reason, that religion is nonsense and furthermore, irrelevant to the warfighting calculous. A military powered on unicorn tears, wishful thoughts, rainbow energy, and hugs and smiles will fail.
Try again.
