The Cost to Own a 430 Scuderia
Athens, GA
https://carsandbids.com/auctions/35k6NDjY/2009-ferrari-430-scuderia
Car currently sitting on Cars and Bids at just above $140k.
They have a bunch of service receipts posted with it. Interesting to see what fluids they've used and some of the repair costs. Looks like a bunch of off-the-shelf stuff you could get at Walmart.
Mobil1 Gear Oil
Peak Coolant (You'd think this at least would be something special)
Castrol Edge 5W40
Penz Platinum Euro Bulk 5W40
Also looks like that by 22,000 miles the clutch is at ~80% used
$2200 throw out bearing replacement.
$62 Ferarri oil filter
Somewhere along the line they needed to do a heli-coil on something. Exhaust from the looks of it.
Pay to play indeed. Service records start at picture #77.
Something I didn't know, and maybe some CA members can speak to this. Car repair shops are required to set tire pressures to factory recommended spec as per state law?
Looks like someone broke in into the car and try to start it by picking a device into the keyhole (I'm not surprised if this happened because the car is in LA, Cali) or the owner is very upset because the car has too many problems :eek:
Looks like the passenger side front quarter panel was repainted because the paint is essentially twice as thick as all the other surfaces. Looks otherwise mint aside from the area around the ignition. Not of fan of these F1 inspired cockpits with carbon fiber everywhere.
It's a shame that so many of these cars are bought but not driven because the maintenance is so expensive.
It's more because of resale value. Once a Ferrari reaches 10k, the value plummets. The more modern ones (360 onward) are not nearly as much to maintain as the older ones (355 previous).
If someone wanted to actually buy one to drive, one like this is a good candidate.
