Interesting articles. Here are a few excerpts:
Quote:
A research study published in the July 1997 issue of Brake & Front End magazine found that pad life was, on average, 62% shorter on a brake job where only the pad was replaced than on a brake job that included a caliper replacement.
Quote:
Visual evidence of caliper failure is present in only 1 or 2 out of 10 brake inspections, and, as a result, shops frequently have to explain why the pads they installed less than a year ago only lasted 15,000 miles.
Quote:
Heat and time dry out caliper seals and reduce the amount of pull-back as the seal ages. A new seal will pull back the piston about 0.015in. In comparison, an old seal may only be 0.010in or less. If the piston does not retract, it can cause the pads to drag.*
References:
http://www.ucx.com/documents/sellcalipers.pdf
*http://www.ucx.com/documents/preventmain.pdf
Perhaps that explains why my Saturn keeps going through rear brake pads at an alarming rate. The calipers pass a visual inspection, the pads are wearing okay, yet my pads are only lasting about 25,000 miles. The originals lasted 100k!
What do you guys think of replacing calipers as preventive maintenance? Would you agree that is necessary at every brake job? The second link provides some fairly convincing evidence on seal stretch, but their example is a bit questionable and seems to represent the exception to the rule. However, it seems to make sense to replace the calipers during a routine brake job if the vehicle has over 100k miles, as components are far more prone to failure due to age.
Discuss.
References:
Discuss.
