(If you weren't around for the discussion before...basically, my front left brake is dragging.)
Well, basically I've figured out the problem...after applying the brakes, the piston is not retracting back into the caliper, causing the brakes to drag.
Guess this means I have a bad caliper?
If so, I do have a question. When disconnecting the brake line from the old caliper and connecting it to a new one, how do you stop the flow of fluid out of the brake line?
Also, when purchasing a new caliper (only around $15 from Autozone), does it come with everything (seals, etc..) minus the pads and bolts?
Thanks.
Thanks.
