To be honest their newsletter was singing to the choir for myself. Im one who would steer more to brands like Pennzoil, Valvoline and Castrol. The engineers at those companies really put their back into this and create some great oils. I tend to think Mobil 1 rests on its laurels. Amsoil produces a great product, but is it that much better then whats on the Walmart shelf? I dont think so.
Blackstone simply posted what I already know which is just buy whatever is on sale at Walmart and dont worry about it.
Nothing could be farther from the truth. UOA results do not indicate internal engine condition. Or whether the oil will result in varnish, coking and carbon. The difference between stuck oil rings or not, is oil choice.
This should come as no surprise to anyone here.
I don’t know, we’ve all seen some of the testing Mobil1 does. I wouldn’t call that resting on their laurels, plus they just changed most of their lineup to their triple action formula a year ago, which they claim is an improvement. I personally think all these companies are pretty similar right now with their additive package/base oils/etc. Ten years ago I thought the additive packages of, let’s say Valvoline, was “different”. They used a lot of sodium instead of moly, and they weren’t the only ones. Now, they all at least look similar on paper.To be honest their newsletter was singing to the choir for myself. Im one who would steer more to brands like Pennzoil, Valvoline and Castrol. The engineers at those companies really put their back into this and create some great oils. I tend to think Mobil 1 rests on its laurels. Amsoil produces a great product, but is it that much better then whats on the Walmart shelf? I dont think so.
This is my biggest concern with oil, and oil change intervals...the piston groves, the oil control ring, and stuck/clogged rings. And I don’t think UOA’s show what really could be happening in that department, because it’s a gradual thing...the cleanliness or lack of cleanliness. That stuff is coking into those areas. It’s not so much the actual wear metals in an analysis, it’s the stuff accumulating in that oil ring groove, between the expander and two control rings. I’ve taken apart engines that look spotless up top, only to pull the pitons out and see carbon and soot trapped in those areas with rings that will not come out into the lands...and oil control rings clogged solid.Nothing could be farther from the truth. UOA results do not indicate internal engine condition. Or whether the oil will result in varnish, coking and carbon. The difference between stuck oil rings or not, is oil choice.
I currently have the Mobil 1 "Triple Action" formula in my engine. We shall see how it stacks up against SuperTechs "Advanced" formula or Quaker States "Ultimate Protection". "Ultimate" seems to indicate it cant get sny better then this whereas a quadruple action beats a triple action.I don’t know, we’ve all seen some of the testing Mobil1 does. I wouldn’t call that resting on their laurels, plus they just changed most of their lineup to their triple action formula a year ago, which they claim is an improvement. I personally think all these companies are pretty similar right now with their additive package/base oils/etc. Ten years ago I thought the additive packages of, let’s say Valvoline, was “different”. They used a lot of sodium instead of moly, and they weren’t the only ones. Now, they all at least look similar on paper.
Yeah, I do think if you want to spend more you may get a little bit better of a product with a boutique oil, but most of us probably aren't going to need the little extra benefit/performance they provide. IMO. I’d still like to try one of those brand though...probables is to justify it I’d have to run an extended drain, and I’m not the type to do that (consistently). Although I have run a few 10,000 mile intervals using Mobil1 EP.
I’m looking forward to when Mobil1 releases a “Dynamic” oil, because then I’ll be able to put it in all my vehicles.I currently have the Mobil 1 "Triple Action" formula in my engine. We shall see how it stacks up against SuperTechs "Advanced" formula or Quaker States "Ultimate Protection". "Ultimate" seems to indicate it cant get sny better then this whereas a quadruple action beats a triple action.
There is no "resistance to fuel dilution". There is resistance to mechanical shearing. Different.Resistance to fuel dilution or shearing was also a big problem in 2018 oils and so much so I turned to Mobil 1 Delvac 5W40 ESP...the 5W30 version wasnt out at that time. Today the API SP formulas are a little more resistant.
The best 5W30 API SP oil out of all the oils I tested is Quaker State 5W40 Euro. Its not a 5W40 but a thick 5W30. The viscosity stayed in the 10s unlike the other oils which were 8s to mid-9s.
What about molecular fuel-dissolving particles?There is no "resistance to fuel dilution". There is resistance to mechanical shearing. Different.
I bet Liquimoly has an addictive for that.What about molecular fuel-dissolving particles?![]()
Do you really think these differences prove that T6 is better? It proves the exact opposite.This is a blast from the past!
In August 2017 Blackstone Labs published a newsletter of averages for a selected bunch of oils for the GM 5.3 liter V8 and the Subaru 2.5 liter turbo. Confirming what many Subaru enthusiasts knew at the time was Rotella T6 5W40 simply outperformed all of the various 5W30s. This was great news for Subaru turbo enthusiasts who used stage kits to push their engine past the limits! Honestly these Subaru guys were really pushing their cars on the track with vastly upgraded turbos. Im surprised they didnt go 5W50 for what they were doing!
However it was bad news for Amsoil as the averages demonstrated that cheaper oils sold at Walmart could compete with it. Pennzoil and Castrol were not far behind Amsoil.
At some point Blackstone quietly removed the report from its website. Link to a pdf copy of that report here: https://files.fm/u/z3ub627wt
View attachment 162931View attachment 162932
Yet we've seen evidence of carbon build up being removed from engines that ran off-the-shelf full synthetics after switching to High Performance Lubricants products.
Nice job re-wording what I said
I drive 70000 miles a year with stop&go and heavy idle. This is my livelhood and not a casual commuting car. If the car doesnt run I dont make money. So its important to me to know the best maintenance items for the car. The 3.5L V6 Ecoboost Ive been married to since 2018 has brought me some challenges.
Shell Rotella T6 5W40 is a wonderful oil.
Delvac is still a great oil.
These Subaru people use kits to push their engines way past the designed limits and then run it at the track. So they wondered into Walmart and found Rotella. They were not wrong in seeking an HDEO. They were wrong in not consulting with Summit Racing first which has a team ready to give out advice. Summit sells the gas rated HDEO Mobil 1 Delvac line as well as other oils more appropriate for modified cars and track racers.
You drive 70 thousand miles per year and change your oil every 3k? That’s twice a month, right? I don’t see how your UOA posted later proves this as being necessary; however, you likely do so for the peace of mind given the truck is your livelihood.
I have never gotten the obsession with Rotella. QS 5W40 Euro is a better product for the gas applications. BRO-Tella.Not the word I would use to describe it. It's 12% Noack, has no moly/FM, foams easily, and is loaded with VII. It's a minimum standard CK-4 oil at best. I know quite a few engines that have eaten a bearing on that oil due to aeration causing bearing cavitation. Every one of them, on teardown, showed a lot of piston deposits as a result of the high volatility.
For a diesel, sure. It's quite lacking in EP which may not pose a problem for an EJ255 but some engines will not be happy with that formula. A local builder to me was venturing into high rpm solid roller LS engines and was just destroyed valvetrain parts, mainly pushrods. He was using Delvac and swearing by it, been using it 20+ years, insisted the pushrod manufacturer was to blame. Switched suppliers twice, same issue, and finally took my advice to switch the oil. He hasn't had a pushrod failure since.
There's quite a few here doing that as well, myself included.
There's nothing special about a CK-4 oil, especially for racing use. They tend to be volatile and lacking in friction reducing additives which is the opposite for what you want for a racing oil. You want low volatility so the oil doesn't evaporate as much around the rings and can hold a better, thicker oil film. You want a lot of friction modifier to drop the CoF for less friction and more power. You want minimal VII loading to ensure the oil is shear stable. There's no CK-4 oil on the shelf at Walmart that caters to that environment. An oil formulated for a diesel engine turning 4000 rpm max with a big oil capacity measured in gallons isn't going to be favorable to a gas engine turning twice that rpm with half (or less) the oil capacity. They're two very different environments that like distinctly different formulas.
That wouldn't be peace of mind for me, neither maintenance wise nor financially speaking. That's a lot of oil.
At $23.48/gal ($5.87/qt) at Walmart for T6, that's $35.22 +tax per 6 quart oil change done every 15 days. That's 24 oil changes a year for $845.28 +tax in oil cost. Amsoil Signature or HPL Premium would easily go 20k miles and have just 3 oil changes a year for
I don't quite get why you started this thread in the first place.This is a blast from the past!
What does this even "prove"?Here is API SN Plus Amsoil Signature 5W30 up against API SP SuperTech Advanced 5W30. Is there any need to get Amsoil anymore?
The other 2 oils on there are Pennzoil Ultra Platinum 5W30 and Quaker State 5W30 Euro.
View attachment 162997View attachment 162998
So, you're comparing UOAs taken 4 years apart, from a different API certification, between two completely different engine families, your sample had 50% fewer miles, and your interpretation from a single data point on each oil you've come to the conclusion that Amsoil as a company is obsolete?Here is API SN Plus Amsoil Signature 5W30 up against API SP SuperTech Advanced 5W30. Is there any need to get Amsoil anymore?
