I recently performed a front pad job on a 2012 Accord coupe. What I noticed was the inside front pads were way too tight. The ears were stuck solid on the clips. Maybe it was rust? Nope. Same problem with the new (Akebono) pads. Way too tight for proper movement. No doubt they would have dragged if I left it like that. I filed the ears down a little bit, much better. Normal. Also noticed someone used standard grease on the slide pins. Was hard as a rock. That would also cause a problem. Cleaned and replaced with sil glyde. Brakes were good after that. No more sticking.
