So I changed my oil in my 2013 Mustang GT today. Based on advice here and elsewhere I went with Pennzoil Platinum 5w30 and a Motorcraft filter. Thanks for everyone that weighed in!
Change went smooth. The last guy that put on my oil filter did it right and I was able to take it off by hand. Huzzah!
I changed a lot of oil with my dad as a kid but this was the first DIY in 20 years. How I did it:
Drove car until oil temp was on the low end of normal.
Checked to see if I could get the filter off before draining oil.
Let it cool until I could hold hand on oil pan for 10 seconds without burn.
Drained oil, waited for a drip every 2-3 seconds.
Took off oil filter (made a mess because of plastic airfoil that only flops down). Used a ziplock bag to catch most of the spillage. Glad I had an oil blanket!
Got about 1/3 cup more oil to drain out of pan when filter came off (had put a secondary oil container under the drip).
Let it drain for another 20 mins.
Primed filter and lubed seal. Hand tightened.
Put in drain plug, added 7.5 quarts of oil.
Checked dipstick then added another .5qt of oil to get to top of dipstick range.
Fired her up, checked oil pressure. Let run a couple minutes then checked dipstick again and for leaks underneath.
No problems, huzzah!
