Originally Posted by oil_film_movies
Originally Posted by Dan55
Toyota refomulated their 0W20 oil for use in the 2015 Lexus NXT2.0 turbo to address LSPI (lower calcium) .
Yes, just like dexos1, SN+, & GF-6 address it. And, notice Toyota-Lexus doesn't want any turbochargers getting deposits, and they know the high moly in Toyota Genuine Motor Oil 0w20 is not a problem.
Note the teost test is a bench test, not a real turbo test. Does it correlate with actual turbos? No.
In fact there was a recent 2017 engineering study which showed the Teost test was at too high a temperature, higher than what real turbo oils experience, and the newer GMTC (General Motors Turbocharger Coking) oxidation test better predicted turbo deposits.
High moly is not a problem.
"Concern about turbocharger deposits is not a new phenomenon, however. In the early 1990s the TEOST 33C bench test was developed to simulate turbocharger coking, and early studies showed a correlation between TEOST 33C results and field issues. A comparison of the TEOST 33C bench test and the GMTC engine test revealed no such correlation between the two tests under the conditions studied. Due to this lack of correlation, a comparison of TEOST 33C response with turbocharger deposits generated during field operation was performed." --
https://www.sae.org/publications/technical-papers/content/2017-01-2341/
Vehicle Tests
Two oils with very different Mo content were tested in Las Vegas taxis for about 194K km (120K miles). Figure 10 illustrates that these two different Mo containing oils generated very different levels of TEOST 33C deposits. The
high Mo containing oil (about 7X Mo) had much higher TEOST 33C total deposits and failed the requirement in current ILSAC GF-5 and API SN specifications. The lower Mo content oil (1X Mo), on the other hand, passed the TEOST 33C requirement.
The same two oils tested in the field showed excellent high temperature stability and viscosity control, very good oxidation control, and excellent wear metal performance (data not shown). End of test engine inspections were performed and the average engine sludge data are shown in Figure 11. Both oils demonstrated excellent sludge control.
To determine if there was a difference in turbocharger deposits, for one vehicle running on each oil, end of test average merit ratings of the turbocharger parts were also rated (also shown in Figure 11). No significant average merit rating difference was observed. The results support the observation that
there is no relationship between gasoline turbocharger cleanliness performance in a vehicle and deposit tendency in the TEOST 33C test. " ------
https://www.thefreelibrary.com/Engi...harger+Protection+and+the...-a0532023053
Thanks for this. New information to me as i too was going to question the Moly content / TEOST33 test.
