Test Shell Helix Ultra 5W-40
Germany
Hi,
just found this on the www:
http://www.italiaspeed.com/2008/cars/ferrari/05/india_tour/shell/2905.html
Any thoughts about the link? Not to shure how reliable this test is...
This is the oil:
http://shop.oil-center.de/index.php/hers...-1x1-liter.html
and the pds to it:
http://www.google.de/url?sa=t&source=web&cd=1&ved=0CBgQFjAA&url=http%3A%2F%2Fwww.wolterwasserbillig.de%2Fuploads%2Fmedia%2FShell_Helix_Ultra_5W-40.pdf&rct=j&q=shell%20helix%20ultra%205W40%20pdf&ei=nrsgTq-gCcSOswbV1bWXAg&usg=AFQjCNHdt7Y5s1B52Sh2jK3rCyRHGSIqFw
Been trying to make up my mind on which oil to use for my 1.8T with a 6250mile oci. The engine has about 106kmiles on it, burns 1/4 liter during the oci and has been runing pretty quiet with Shell Helix Ultra (0W-40 and 5W-40).
The gti 20th mk4 is driven in germany and this mostly on the autobahn around 100mph most of the time. About 3-4 times a month I´ll top it out. Enginemanagement has been remapped making about 19psi, Katback, downpipe and so on...
So I´ve been considering of sticking to Shell Helix Ultra or switching to something like Mobil 1 Peak Life 5W-50, maby Mobil 1 NewLife 0W-40. But kinda worryd with the Mobil 0W-40. Last time I used it the engine was kinda noisy on start up and warm up...
Droppet GC out of my list cause of the hard driving on the autobahn i do every once in a while
Just want the engine to stay as clean as posible and last as long as possible
So anyway, what do you guys think about the test from italianspeed.com?
Thanks
Speziell für verlängerte Ölwechselintervalle entwickelt. Geeignet für Benzinmotoren, die mit Katalysator ausgerüstet sind - auch unter extremen Bedingungen. Außerdem geeignet für Hochleistungs-Turbo / Dieselmotoren ohne Dieselpartikelfilter.
Hohe Temperaturen im Motor und verlängerte Ölwechselintervalle belasten den Motor zusätzlich und können zu einem verminderten Ansprechverhalten und geringerer Leistung führen. Shell Helix Ultra wurde mit der aktiven Reinigungstechnologie von Shell formuliert. Damit können bereits vorhandene Verunreinigungen gelöst und der Aufbau von Ablagerungen kontinuierlich verhindert werden. Der Motor wird geschützt, das Ansprechverhalten steigt und der Motor kann bis zum nächsten Ölwechsel seine volle Leistung entfalten.
für Benzin- und Dieselmotoren (siehe unten)
basierend auf Synthesetechnologie
für BMW, Mercedes-Benz, "VOLKSWAGEN", Porsche, Renault, Ferrari und Fiat
Das Gut
You guys should know as well as I do that any engineoil writeup will state that it´s the best
Not trying to be an [censored] about the coments, but I dont need help reading engineoil writeups
