Yep, and it wouldn't be a good outcome.Living up there in the other “mandate capital” - I can see a very different EV outcome coming vs sunny CA.
Which trim did you have?I had a rav4 Prime. It did not feel quality. In any way. I can't see how the eGMP twins could be worse.
Ok I pulled up the results. I wasnt sure if it was seconds or beats. It was beats. I found it curious that they never tested my magnesium. I know all about that from my brother. The only reason I think its not related was I eat healthy and also take a daily vitamin that has a min of 100mg of it. I know you need roughly 400. But now that you commented if I saw this before maybe I would have told them to test for it. Curious, my brother who is a train wreck with his heart always told them to test for it because they never did but it always showed up ok. Even then he took supplements to bring it to the higher range.I am sure labwork has been done and your magnesium levels are normal?
8 seconds of vtac is probably near a good 20 beats. This is very uncool. I definitely think that if this is medicated, it is insufficient for the condition and you definitely should have the procedure. Just my opinion.
XSE. No not trim depending, its just a Toyota. Interiors are low quality. Chassis is meh. The engines and transmissions are g2g.Which trim did you have?
Is its trim level dependent?
I was looking at the XSE as 40 miles a day gets done most of what I need.
Yeah, that is a lot of pvcs. Some are normal. Most people don't notice them. Text book is 6 per minute max. The vtac even for 8 beats is not normal. I presume you've already had a clean heart cath, echo to verify ejection fraction and valve function, and maybe a stress test? I am surprised they didnt do a basic metabolic panel with magnesium. Magnesium is directly related to ventricular irritability. Occasional PACs arent a big deal. They didn't even provide you a count, so Id not stress too much on them for now. I am just curious what the underlying cause of all of the ventricular irritability is, here. I am a big fan of address the cause and not the symptom, if possible. You don't keep putting new tires on the car every 5k miles....you fix the alignment issue.Ok I pulled up the results. I wasnt sure if it was seconds or beats. It was beats. I found it curious that they never tested my magnesium. I know all about that from my brother. The only reason I think its not related was I eat healthy and also take a daily vitamin that has a min of 100mg of it. I know you need roughly 400. But now that you commented if I saw this before maybe I would have told them to test for it. Curious, my brother who is a train wreck with his heart always told them to test for it because they never did but it always showed up ok. Even then he took supplements to bring it to the higher range.
Anyway, I pulled up my results. I LOVE the system where I am, I have almost all my test results and comments online.
(some are also on the Dr side that I cant see. What concerns me a little without taking the medication if the ablation goes well. The ablation will not take care of the PACs if I understand and why my Dr said if it was him he would try the med first.
Here is the holter result
· Normal sinus rhythm with a minimum heart rate of 51 and maximum heart
rate of 154. Patient had 24,616 PVCs and 917 couplets. There were
occasional PACs. There was one 8 beat run of nonsustained V. tach at 170
bpm.
Honestly, just get a real EV. Im much happier with full EV than my Prime. The awd is horrible in the prime. 80%+ hp goes to front tires.Bummer, on the surface it has promise.
Love the range.
That has always been the Toyota approach - solid powertrain that is designed for long-term serviceability, good long-term support network but mediocre for everything else (from a performance and appeal standpoint).Bummer, on the surface it has promise.
Love the range.
I'm waiting for something reasonably priced, that charges quickly and has long range.... (like everyone else)
The new chevies show promise, but Im going to wager the 1K mile trip metrics will be disappointing.
I may just get a new civic EHV until the EV's come downmarket a bit.
The new 800V architectures are extremely promising when paired with the 350KW DC fast chargers. 10-80% in 20-25 min, which is perfect for a every 200 mile stop on a road trip. It pretty much matches (and sometimes beats) the Tesla V3 Superchargers. Even the older 150KW chargers, when paired with the 800V architecture cars, are not far behind.
Realistically, how often do you expect to fast charge? It should be a once-a-quarter thing at most, IMO. 95% of the time you would be charging at home or at your destination using a 6-11KW Level 2 charger. At least with the Tesla crowd, there still seems to be10-15% of range loss after a few years despite using a conservative charging approach.I'm eager to see degradation tests on the latest wave of 800V Asian rides.
Based on Bjorns metrics the 800V architectures haven't really delivered what the brochures promised.
The EV6 and IONIC 5 deliver in spades.I'm eager to see degradation tests on the latest wave of 800V Asian rides.
Sort of.The EV6 and IONIC 5 deliver in spades.
Probably going to see more battery degradation with that approach vs someone who charges at home, but at most.....you're looking at a few percent per year. Probably not the best use for the vehicle, IMO, though.6-ish times a month.
I have multiple reason to travel to So cal, and its about 950 miles there and back. I do this every month or at most two.
For in town stuff it can slow boat at night, but on these trips Ill be quick charging at least 2-3 times each direction.
The lifespan of EV's is probably akin to an iPad. Longer than an iPhone, but really a 5-10 year item. I don't see them being viable for longer road trips after year 5 given that folks are already seeing 10-12% range loss after a few years. I think a lot of people still forget that time kills batteries more so than mileage, so these 100K reviews after 2 years are not of much value. The issue is that these cars are only good for 150-200 miles between charges as-is (10-80% SOC usage) under "normal speeds," so a loss of 10-20% can make them go from being "ok" long trip cars to intolerable.No doubt.
This is why a known entity is important for me and anything "new" isnt really workable until I see some degradation curves.
