Alrightey than, some of you may know that i have had some suspension noise in my silverado. In the morning mostly it would make a loud CluNk! when suspension would travel. Only from the front. Like someone knocking the bottom of the cab real hard. It was very anoying so I decided to finally fix the problem.
First of all, My lower control arm bolts were not even finger tight! I could unscrew the nuts with my hands. What the [censored] is that?.. Anyway after busting out the good ol' 1/2 gun, There tight now. So I drove around the block, still noise. Now i find out that my sway bar links are loose as can be. I tightened them up real good and now the truck rides like a cadillac. (Almost)
Has anyone else had these problems? Trucks only got about 90K miles now
