Originally Posted By: joel95ex
i had an inspection and seperate termite inspection before buying this house las august. both were clean inspections. this morning I saw a swarm of termites on a crack near the foundation and the sidewalk (the sidewalk touches the foundation) i started poking in the crack and saw worker termites. I have a hard time believing they are suddenly here when they were not here in august---maybe I'm wrong. we have no evidence of wings or anything inside the house---also no tunnels aroung the foundation/slab. I am calling the pest control people out here, but my question is, how long does it take for the worker temites to show up----did the termite inspector do his job? I am NOT very happy right now. I was going to get the house treated this summer, but now I am freaking out. How much should an average termidor treatment cost for a slab 2300 (counting the garage) square feet. Please help!!!!!!!!!
Termite inspections and home inspections IMO are a bunch of [censored] most of the time, and another money maker. You must hire a company with a proven track record, or you're tossing money down the drain. I've uncovered more problems in customers homes over the years than so called Termite inspectors and engineers ever found. Basic stuff too, like a lousy insulation job, improperly installed flashing and roofing, that anyone with any degree of competency would have uncovered.
When I bought my home I paid good money for a termite/carpenter ant inspection because I was unsure of what exactly to look for. Shortly after moving in I decided to bump out my garage. There was a carpenter ant infestation, and destroyed wood that would have cost thousands to repair had I not done the alteration myself. I also had damage to a bathroom that was constructed from part of the garage by the prior owner. I had to totally replace the bathroom. I learned how to detect for ant and termite damage as a result of that. My damage was discovered about 1 month after the so called inspection. If you read the fine print of these inspections they cover the person doing the inspection nicely. So if damage is later discovered and it does go to court most people taking the inspector to court don't have a legal leg to stand on.
To the OP, I have no idea how much termite treatment costs in Texas, in NY it is quite costly. All the treatment will do is kill the termites and stop them from doing further damage. Hopefully create a barrier to protect against more damage. You need someone that is good at damage detection to give you an idea if any real damage was done yet and the cost of repair. Since they come up from the ground I would check for mud trails along cracks in the foundation, and poke around and inspect the sill plate for damage. There is some good info on the WWW that will help.
