In the past few months my car usually gets around 24-26 PSI @ idle, now that it is warming up outside, I'm seeing that my oil pressure is dropping down to 19-21 PSI. Keep in mind, I'm still using the same oil and same oil filter. I'm also noticing more smoke when I'm at WOT. My compression reads 270psi +/- 3psi across the board.
Any reason behind this?
LSV
LSV
