- Joined
- Aug 4, 2021
- Messages
- 67
I have a 99 Sierra 1500 with a 2003 Silverado 4.3 engine. I took it on a regular off road trip and drove it kinda hard and after my oil pressure hasn’t been the same. I use to have 20psi when idling hot and in gear and about 55-60psi highway cruising. Used k&n with royal purple since I would get it very cheap but I wasn’t good with oil changes at the time. Horribly bad I know. But oil pressure went down and thought oh probably just need oil so I changed it and oil pressure hasn’t been the same. I have a aftermarket mechanical tube gauge on a A Pilar. I have a after market brass fitting that goes where the sending until would so no screen. And “change oil light” is always on even after changing oil. Changing oil raises pressure but only lasts a month before the Pressure goes to 0 at idle. I have a bad leak but with the lift kit I have cross member cannot be removed so no dropping the pan. I have to put a quart a week. During the week full of oil the pressure is fine. But after a month even being full of oil or making the oil thick I can’t get the pressure even to 20psi idling until I change the filter. Could there be a clog from not changing it when I wouldn’t change it? Or probably cam bearing? No lifter noise no knocking. The engine runs very very strong and has good compression. If that helps any. Also I’m new and young and don’t know a lot. Any opinions or suggestions would be greatly appreciated
