doublebase
Thread starter
- Joined
- Dec 28, 2014
- Messages
- 3,023
Excellent and a great demonstration of what it takes.Some other cars I’ve owned have made it up there, but to keep it simple, I’ll focus on the one we have now, a Volvo XC at 266,000. No rust, good paint, nice interior, so worth maintaining and keeping. Most recent work was a commitment to keeping it past 300,000.
So, in no particular order...
Lots of oil changes (was 7,500, now 5,000)
Lots of transmission, differential, brake fluid changes
Lots of air, cabin, fuel filters
Lots of tires. Lots of tires. The thing eats tires every 30,000 miles.
Front calipers
Brake hoses
Two sets of rotors and pads
Three timing belts
Water pump
Radiator hoses
Power steering pump, hose and reservoir
Cam and crank seals
Complete Flame Trap (PCV system) replacement
Two complete* suspension rebuilds
Rear sway bar bushings
Front right axle
Transmission valve body rebuild
Added transmission cooler and external filter
Front differential seal repair
Engine mounts
Down pipe (with cat)
Turbo compression bypass valve
Silicone turbo hoses to replace rubber
Exhaust manifold gasket set
Three sets of spark plugs
Two new coils (of five COP)
Headlight wiring harness repair
Wire loom (wrap) repair around engine
Vacuum hoses replaced with silicone
Lots of work, much of it as the car went past 200,000 and rubber/insulation simply wore out. The head has never been off. No engine internals. Transmission is still original. Still looks and runs great. Good power, good MPG. No car payment on it, ever. It was bought used in 2007 for $12,000. Even with all the work added up, and considering zero payments for 14 years, it's been a great car, and fairly inexpensive to own.
*Suspension rebuild includes shocks, struts, strut mounts, spring seats, ball joints, lower control arms, inner and outer tie rods and boots, and swaybar end links. Most recent one, this month, included new front and rear springs.
Honestly, a lot of people have had great success at the 200,000 mark, but to get it to 300,000 takes a bit more.
I should have mentioned that a good deal of my repairs came after 250,000 miles...subframe, steering rack, EGR valve, transmission switches, second charcoal canister. Some more.
