Taurus Filters
Dixie
Katsdad,
A FRAM "PH8A" equivalent will work on this engine, provided there is room for the wider/longer filter.
These are approx 3.75" diameter and 5.25" long - in comparison the PH-3600 is 3.00" diameter and 4.75" long. As I recall, the filter mounts horizontally on this engine, so the replacement filter should also have an anti drainback valve. A slightly shorter version of this filter is the Mobil 1, M1/204. I can run this on my four cylinder, Toyota Tacoma in place of the PH 3600 filter.
Are there larger choice's to the standard size?Usually numbered, company prefix then 3600. I have the 3.8 litre engine. Thanks
