Equivalent Filters to VW Canister Type (for an Oil Cooler)
Canadeh
Hey all, I have a little project going on trying to adapt a sandwich thermostat onto a car (VW MK7 MQB platform with the EA888 Gen 3 engine) that was designed for a canister/cartridge type. Due to space constraints, I cannot reuse the OEM plastic filter housing because it will hit the hood, hence I'm trying to find a spin on low-profile equivalent.
Did a bit of due diligence and messaged a few of the companies that makes the OEM filter and here are the replies:
1) Baldwin/Parker
2) MANN+HUMMEL
3) WIX (owned by MANN+HUMMEL)
4) MAHLE
What I've found is that nominal and absolute ratings are all over the page. I've measured the stock VW bypass spring to be in the ~10lb neighbourhood, so if the spin on filter has a bypass in it, it just needs to be equal, or higher. The OEM VW bypass/pressure relief mechanism is a separate part which I will be retaining. Technically, that mechanism also includes the anti-drainback valve, an all-in-one if you may, hence the spin on doesn't have to have anything, other than a filter.
I've narrowed it down to:
1) Mazda N3R1-14-302 (Tokyo Roki)
2) Mazda PE01-14-302 (Tokyo Roki)/WIX 57002
3) Mobil 1 M1-108/108A
4) Nissan 15208-65F0E
5) WIX 51356
Will any of those meet the micron specs from VW/VAG? This is purely for a racing application, so at most 10K OCI, and again, I picked filters that were shorter in height. Diameter, I can go up to ~90mm (let's call it 3.5"). Oil is full synthetic.
Thanks!
Paradise of Florida
Racing 10k oci? My non racing is 5k on my VW.
You have a 20mm remote mount?
Use a racing filter like Fram HP17 or from gopurepower
You did the research most are afraid to do....verified pathetic OE filter specs.
burgerkong
Canadeh
10K at max, kilometers since Canada haha. But I figure some guys aren't as religious, so 10K to be safe.
The stock VW is right at the top of the engine, and with a 1.5" thick sandwich plate, I can't run regular sized/tall filters. Trying not to go remote mount to keep it all OEM like and run less lines.
