All,
I want to run T adapters between the hoses and where they go into the 90 degree fittings in the picture below. The idea would be to run a small feed to the Motorguard (or other) bypass filter off of the input hose to the remote filter, and then dump the return line (from the bypass) into the return line from the remote filter.
I kknow this would work if I dumped the bypass return line into the valve cover or some other return, however, it would be cleaner to do it as described above.
I'm wondering if there is enough pressure delta (caused by the FF filter) between the input and output line of the remote FF filter set-up so this could be accomplished.
