Tapered ball joint shaft seized in - help!
Originally Posted By: NoNameJoe
Quote:
Wow, after all that banging ... the tool looks so insubstantial, but it sure did the job!
These days I don't even attempt any service unless I have the proper tools for the job. This is a perfect example.
Ask yourself was it better to waste all of that time and effort banging away with a hammer or just buy this and get it over with? I know which one I would choose.
Agreed, if I'd known that the tool even existed, and that it was available locally, I would have bought it in advance in a flash. Oh well. lesson learned.
Normally I would have planned out the job better, but this was an emergency repair.
Pics (finally):
This was putting the broken side back together in the driveway, after getting the steering knuckle back from the machine shop.
Here's the new LCA w/ integrated ball joint in place:
Here's the steering knuckle back in place:
This is the stabilizer bar end link reinstalled:
Here's the old ball joint that had separated:
Did the other side in the garage, with the construction heater running. Much nicer! And you can see the amazing tool that I wish I'd known about for the other side!
Here's a close-up of the 'good' ball joint. I really ripped up the boot with the pickle fork, before using the special tool. Lesson learned!
