3rd Gen Taco calls for 75w85 gear oil, front & rear. Should I throw the 75w90 I have in it, or order the "correct" fluid? New to Toyotas.
Thanks!
Thanks!
Thanks! I should have searched for more that "Tacoma Diff" smhYou may be interested in these discussions:
So I just picked up a 2016 Toyota Sequoia 4x4 with 197K miles (previous owner apparently drove a lot)
we will be doing occasional heavy towing, I move a lot for work and tow a large enclosed trailer. the rest of the time its a grocery getter and kid hauler and the wife's primary vehicle.
Given the miles I want to baseline all the fluids to fresh synthetic,
issue is the diffs and transfer case
front and rear diffs call for a total of 3.81 qts of 75w-85 GL-5
the transfer case call for 1.43qt of 75w-90 GL-5
I am annoyed by the slightly different viscosity, part of me just wants to...
- RavenTai
- Forum: ATF, Differential, Trans, Brakes, P/S
Hey Everyone,
Our 2019 Santa Fe specs 75w-85 in the transfer case and rear diff.
In the past I have used 75w-90.
I was wondering if you all think the 90 weight would be better for longevity VS .005 mileage increase for the 85.
Thanks
- nicholas
my Tacoma truck requires using a 75w85 gl5 type gear oil in the differentials, since im limited to using either the Toyota brand gear oil or the redline lightweight 75w85s, what other gear oil would be the best close alternative to those.
- jrvn
see a lot of people asking if their specification 80W-90 can be substituted with something else. Invariably the chorus here says "use 75W-90 is better because muah, synthetic".
Since my car differential and transfer case also requires 80W-90, I kind of thought... why Toyota din't say 75W-90 if that was so great?
To start, I measured my differential temperature after running 30 minutes in 70 F ambient. Result: 110...117F. For people in the rest of the world that's 43...47C.
I am curious... let's take a look at the viscosities of various gear fluids at this temperature. Not at frozen -50C...
- SoNic67
Hey Guys,
Sorry...but another Super Tech question. Toyota calls for 75w85 or a GL5 equivalent. 75w85 is not east to find at all! Any issues with going with Super Tech 75w90 Syn gear lube in the front and rear of the 4Runner?
Has anyone used this...is it a pretty decent fill? Looks to have the legit specs....
- Doublehaul
So we have 2019 santa fe AWD, oem.is 75w-85 usually our other cars have used a 90 weight.
My question is......did they chose an 85 weight for meg's or longevity?
We want to keep this car a LONG time.
Would you swap it out for a 90?
- nicholas
My 4WD truck calls for 85 in the front axle and rear diff, and then for -90 in the transfer case. Would it be safe to just get a case of the 90 and use it everywhere? Seems absurd to be buying all those single bottles for 5 points of viscosity. Thanks.
- Hot_Ajax
My 2011 Toyota Tundra calls for 75W85 gear oil for the rear differential. This weight is pretty hard to come by...can I use a good full synthetic 75W90? If so, is Mobil 1 a good choice?
I plan on changing the rear gear oil early because I want to squeeze as many mpg's as possible out of my truck given these high gas prices. I have heard a good quality full syntheic gear oil may help some, as well as offer really good protection long term.
Any feedback would be greatly appreciated. Thanks...
- 1999cutiger
Hello Everybody,
We just bought a used a Hyundai i10 (PA) 2012 1.2 liter Petrol car with ~132K Km on it and a manual transmission.
We want to maintain it before use and so we are contemplating an oil change (especially since these cars are generally used in urban conditions and by young people as a first car, so the trans must have been a little abused if we had to guess). Also, please note that this car will be used by the wife for 95% city driving, daily from home to work/gym/groceries( we have another car for longer travels).
The manual asks for 75w85 GL4 oil but I don't find any...
- slimypi
- 75w80 75w85 75w90 advice gearbox hyundai maintenance manual oil transmission
Well I just found out that my '09 toyota comes stock with 75w-85 in the front and rear diffs. Toyota even issued a TSB for older yotas to start using the stuff. Does anyone have a PDS on this stuff? Who's making it? It's crazy expensive... Lists fore $31.28/liter. I can get it for $23.50/Litre through a discount yota house. That's borderline insane. Toyota states the reason for this lube is Fuel Economy. Maybe CAFE? I'd love to see a PDS on this stuff. I wonder if it's even GL-5 rated. Castrol's 75/85 is GL-4 only.
Other issue I have is they did not mention running it in the...
- 4x4taco
I just used Amsoil Severe Gear 80W90 GL-5 gear oil in the rear differential of my 2020 Toyota Highlander XLE AWD since that's what my 2013 Highlander called for and I had an extra bottle (squeeze bag?) laying around. 2020 Owners Manual calls for Toyota 75W85 LX Gear Oil.
Am I OK to leave until next diff oil change or should I change oil to recommended 75W85 or more readily available 75W90?
- Moonn
Hello all,
I am in the early stages of considering purchase of a 2011 Toyota Tacoma V6 4WD. As part of the research into this possible purchase, I downloaded a copy of the owner's manual and read through it. I was surprised to see that Toyota specifies 75W-85 for the Differential. I thought this was interesting. I know Red Line makes a 75W-85, but I am not aware of any other offerings in this weight range. I believe Toyota is still recommending 75W-90 for the transfer case and front differential. Will 75W-85 become an increasingly common viscosity range? Do other vehicles out there...
- btanchors
Is anyone aware of a commercially available synthetic 75w85 GL5? This is the oil spec'd for the diffential in my Lexus (aka Toyota).
If not, does anyone have any idea if Lexus/Toyota dealers make the standard 75/85 available to customers?
- heffergm
Yep. I have about 18 qts of Amsoil Severe 75w90 for some of our other vehicles. That was my plan.If you already have 75w90 on hand, I would use it. But if using OEM grade makes you sleep better, use it. Either grade will work perfect in your Taco.
Never failsYou may be interested in these discussions:
- RavenTai
Hey Everyone,
Thanks
- nicholas
- jrvn
- SoNic67
Hey Guys,
- Doublehaul
- nicholas
- Hot_Ajax
- 1999cutiger
Hello Everybody,
- slimypi
- 4x4taco
- Moonn
Hello all,
- btanchors
- heffergm
There is nothing to think about. 75W90.Yep. I have about 18 qts of Amsoil Severe 75w90 for some of our other vehicles. That was my plan.
Seems odd anyone bothers to make 75W85 …There is nothing to think about. 75W90.
75W85 is there just to help fuel economy. And it doesn’t![]()
Automakers do anything to reduce fuel consumption, even use a unicorn gear oil grade.Seems odd anyone bothers to make 75W85 …
Saw a claim that RL’s is actually a mono … Dunno …Automakers do anything to reduce fuel consumption, even use a unicorn gear oil grade.
