So about a year ago I replaced the stat in my 90 Silverado. Ever since on cold mornings I watch the temp gauge while driving waiting for the stat to open and have noticed the following. Gauge will run up to about 215 before I first start seeing it open. After it opens the gauge will go way down to somewhere near 130 then start to climb again. It will then always over shoot to about 220 before it opens again. The stat is a Standt that was purchased at Oreilly's. Since I am replacing intake gaskets I went to my Chevy dealer and got a GM 12514334. Upon unboxing it I noticed that this new one is a standt as well but everything about the GM piece is different. The pills are different, the stamped parts are different. My question for you pros is are factory stats built to differing quality standards than the aftermarket from the same manufacture?
I sure thought that the old stat should be able to control temps better than this thing has. And I guess I thought I had trust in the Stant name.
