- Messages
- 118
- Location
- Long Island NY
I have been reading this forum for a while now and there is a ton of great information here , but the one thing that I have learnd is if you change your oil often and use a decent oil your motor will last 200k easy.Now the question, Red line oil cost 9.00 a quart aprox. and Schaeffer's cost 3.00 a quart for the blend.Ok say you have a high end filter (mobil 1, K&N) or whatever and you are running redline in this motor with 9-12k change intervals,the other motor is running Schaeffer's blend with oem filter or other low cost filter at 3-5k change intervals, same cost more or less.What would be better in the long run for the motor, one oil change every 9-12k with a quality synthetic, or more frequent changes (3-5k) using a good blend like Schaeffer's? From what I have seen on the UOA it seems that a good oil like Schaffer's does holds up just as well as most synthetics sometimes even better.Any thoughts?
[ March 23, 2003, 07:48 AM: Message edited by: plexx ]
