2000Trooper
In the 4 cylinder Toyota Truck community many of us are having issues with the oil pick up tube seal drying out & deforming. You can see what the seal looks like new versus coming out of the truck. This is on older 2.7 2TR-FE motors and not the new turbo motors. Issues with cold start oil pressure arise anywhere from 80-120k miles.
I’m betting today’s heavy PAO bases are likely to be the culprit. From what I could gather searching on here, old mineral based oils prevented this by keeping the rubber soft, and esters can react with the rubber in a similar way. Where as PAOs don’t due to their non polar nature, and dry it out.
With that said, what % of ester in the base will be adequate to keep seals in a healthy condition? What about to rejuvinate the seal? I know manufacturers like to skimp out on esters due to cost so “synthetic” oils have a wide spectrum of ester levels.
Could an oil change with an ester heavy oil like Motul 8100 get an old seal back on shape? Or is it wishful thinking? There is a member on another forum that claims switching to Mobil 1 stop the issue for him completely.
