Don't forget oil thickness. A thin 10w30(like Mobil1) will drain back quicker. A thicker non-synth 10w30 might hang around longer.
If measured viscosity(not bottle label wide range) is the same, then either should flow back to the pan in the same amount of time(exluding any oil affinity if it makes a difference).
