- Messages
- 751
- Location
- Texas
I have a book written by Leslie R. Sachs a Harvard graduate with 5 degrees from 3 universities and James S. Bennett who has driven, repaired, rebuilt, bought sold and counsulted on a wide variety of used cars. He holds an advanced degree in management and is an expert motorcyclist. The book is "Cheap Wheels".
Under Synthetic Oils it says:
"Synthetics flow so well that they do not always stick to the engine parts when the engine is turned off, like regular oil will. SAE 5 w-30 synthetic flows far better than regular SAE 5 w - 30. This means that for a period of time when you start the car there is no lubrication on some parts of the engine because the synthetic oil has flowed away from some engine parts. The older the engine the easier it is for the oil to flow away. We don't recommend synthetic oils."
This got me thinking. I have a 1987 Camry 4 cylinder that runs smooth and doesn't use oil. It has 168,000 miles with no problems. I left it sitting for a week while I was on vacation. I ordinarily drive it 6 days a week. It was obvious that as the starter turned over the engine the compression was uneven. It smoothed out as soon as it started. Would it be a good test if I drained the synthetic and put in a good conventional oil and tried it again on my next vacation which is this month. Will the conventional oil stay in the rings better? The car had 116,000 mi on it when I bought it. I need to get over 200,000 on it. I know the history of the car. Bought it from a friend for $600.00.
Ralph ![[Burnout]](/forums/graemlins/burnout.gif)
