"No sure what your question was, Pablo.
API certification means(at least to most folks) that the oil was tested and evaluated by someone other than the manufacturer, or their paid consultants.
I'm sure, knowing some Amsoil dealers, that any answer that doesn't fit with Amsoil advertising hype/propaganda would be discounted or ignored in any case."
My question was: "Can you tell me what API certified means? And why this bothers you so much?"
Not sure why the attitude cop. I merely wanted to read your reasoning, your level of knowledge on the subject matter. We are all learning, but to call everything Amsoil does "hype/propaganda" is a prety broad stroke, and sorta smacks of what you accuse them of doing. As I have stated I like to keep the opinions, the faith, fact based
I have nothing against API. They are a large "institute" and do much more than motor oil. One thing I think people miss is that ILSAC (International Lubricants Standard and Approval Committee) actually sets the standards, the requirements. API only does the logistics of the approval.
I do not speak for Amsoil, but Amsoil has never had an issue with the ILSAC (sequence) performance standards. These standards can be considered as minimums - and until SL-SM hit the streets were not terrribly tough to meet. Amsoil has always far exceeded the performance test requirements of ILSAC. You don't have to believe this, but to imply that the oils don't meet or doesn't exceed, needs to be backed up factually. To continue down that line and say that the only good oils are "API certified oils" is disingenuous at best.
Indeed Amsoil has not agreed with the P lowering (on XW-20/30 PCMO's), (SJ - SM,SL) and has used this in their "reasoning" statements. It is interesting to see Amsoil lower their P levels as they follow the additive manufacturers as Buster states. However - Amsoil's major objection has been and remains to be the API formulation control and base oil substitution rules. Amsoil wants to remain staunchly independent - yet they like to make a buck, too. Hence the XL line towing the line for warranty reasons and mainly because new cars probably shouldn't go 15K+ miles on the second OCI.
Amsoil does some of their own initial testing on ALL their oils. Then they send them out to an independent, approved lab - of course Amsoil pays the bill - who else will. Who pays the bill for API testing? Yes! It costs big money. Go back and read Too Slick's post - he didn't pull those numbers out of his a-z-z - these were done by SWRI. I highly doubt that renowned lab pulled the number out of their a-z-z. And of course there is the BITOG test.
http://www.ppcouncil.org/apimarks.htm
http://api-ep.api.org/filelibrary/API_MotorOilGuide_2004.pdf
http://www.swri.edu/
http://www.amsoil.com/performancetests/sequence_3f.aspx
Stingray427 - Amsoil ships UPS from regional/local warehouses. How fast? A couple days.
Yes:
http://www.amsoil.com/storefront/svg.aspx?zo=515729
http://www.amsoil.com/StoreFront/atf.aspx?zo=515729
