This is the lower-hp higher-torque LT1 in a 96 Roadmaster wagon. Lots of short and medium trips (Home Depot and several other stores are 1/2 mile away, other frequent targets 5-15 miles, lots of surface streets with 5 miles of interstate in the middle) and occasional 150-250mile all-interstate trips; north AL just-below-freezing to 4 months at 90-100 degree weather. About 144k miles.
(The same questions below also apply to a 92 Roadmaster L05, i.e. previous-gen smallblock 350, that gets a slighly hotter version of the same weather in Auburn AL and the same driving plus more 250-mile trips up here. About 130k miles.)
After years of Mobil 1 5w30 and 10w30 up north, I found BITOG and references to Mobil 1 xw30 being a bit thin, and the Mobil 1 5w40 I have around for my TDI anyway. Also, every time the Mobil 1 5w40 got hard to find, I used GC. (I have another wagon like this that got to 222k+ miles with the same treatment, and is only now dying of frame rust.)
These days, GC is always $8/qt. for me and I read it's possibly a little less miraculous compared to other oils now than it used to be.
Mobil 1 5w40 is suddenly in plentiful supply at $26/gal at Walmart again, which also has most other Mobil 1 oils that might be considered at $23/5qt.
So the price differences aren't big, but is there anything to recommend Mobil 1 5w40 over Mobil 1 5w30 or 10w30 worth spending probably $9 more per change? Is there something in the ESP (or whatever suffix) oils, or the green-cap 0w30, to recommend them over 5w40 even regardless of price?
I've read very good things (even for TDI use?) about Mobil 1 0w40, but is it appropriate for these kinds of engines?
