two LT1's, Saturn, oil recomendations?
Florida
I have two LT1 motors, if you dont know what they are they are 5.7 ltr v8's, aka 350's, mainly used in the Corvettes, but were also used in 94-96 Cadillac Fleetwoods, Chevy Caprice and Buick Roadmaster. I have two Fleetwoods. One sits in the driveway with a dead transmission, I changed the oil and filter today with Delvac 15W40 and a cheap Purolator filter, it has 117k miles on it. I last changed the oil 2,700 miles ago or 9 months, with Mobil 1 5w30.
The next one is another lt1 with 177k miles. Right now it has dino Napa 10w40 oil, and a cheap Advance autoparts filter, with less then 50 miles, ive changed the oil/filter twice on this car in less then 55 miles, the car had been sitting on a farm, just to make me sleep better at nite. I bought a Pureone filter, and plan on filling it with Delvac 15W40. As soon as the car is registered and driven, I will change in 3 months and get an oil analysis to see how it is performing. I drive my cars hard and tend to idle quite a bit.
I also drive a Saturn SW2 with 1.9 dohc. I commute 28 miles a day to work, 80% highway, 20% city, and do encounter some stop and go on the interstate in the morning and in the city. I use Mobil 1 Extended Performance 5w30 with a K&N filter. I will probably go about 8,000 miles on this oil, I drive the car hard, the engine does rev high, I idle at least 15 minutes a day, some times I idle during my lunch hour 30 minutes to run the a/c, when I get to my destination i will some times idle for 5-10 minutes till I get out to keep the a/c going. I wish I would have used 10w30, but maybe next time. I will be getting an oil analysis when I change the oil in the begginning of December. The oil has about 5k miles and is just beggining to darken up, I can still see the dipstick through the oil. I live in FL as well.
Feed back welcome. Is it bad to run thick oil in a DOHC high revving engine?
I think that you made a good decision on all three accounts. Mobil 1 Extended Performance is a good oil and if you want to do analysis at 8K. That is a good decision also.
I like Mobil products, I just wish they made a 10W40 in EP, I'd buy it. I cant wait to see how this Delvac turns out, its not actually a synthetic oil, but because of the higher additives it supposedly has and thicker grade it should perform good, right?
IIRC a lot of people would agree that while Mobil 1 5w30 and 10w30 work okay in an LT1 engine you'd get better results from the german Castrol 0w30 or the Mobil 1 "Turbo Diesel" 5w40.
I myself was not pleased with Mobil 1 0w40 oil analysis' in my LT1, so I think im going to try some of the 5w40 when I can locate it.
quote:
It's not bad, but you will lose a bit of power and burn a bit more fuel. Whether it will be a big enough difference to notice or not is another question.
