Propflux01
$100 Site Donor 2026
Christine would differ with youI've done it. Nothing will happen. The car is not sentient and doesn't know what brand of oil is in it.
Wish I had a car that rebuilt itself minus the possessed part.Christine would differ with you! View attachment 150131
Age old debate. I'm usually more of a purest as I don't like to mix oils, nor do I like to constantly switch back and forth. Does it matter? Meh probably not much. But each time you introduce a new chemistry into the engine, it has to lay down it's qualities and establish new tribofilms on the metal surfaces with it's own unique chemistry. Being most oils are compatible, it's not really an issue. I prefer to try and stay with one brand. I know we all get the urge to try new oils now and then and that is perfectly fine.I see a lot of folks sticking with one brand, and saying it’s best to do so, the question I’d have is...what’s wrong with switching every oil change? In the last 70,000 miles on my current vehicle I’ve used Mobil 1 Extended Performance (3 times), Pennzoil Platinum a couple times, Valvoline Modern Engine a couple times, Shell RGT, Super Tech, Amalie Synthetic, and I used a frankenbrew of Pennzoil/Quaker State/Shell RGT. Intervals ranging from 5,000-10,000 (when using the Mobil 1 Extended Performance).
If there is ANY advantage to sticking with just one brand, I might actually do it. And it’d probably be Mobil 1 I guess. And probably Mobil 1 Extended Performance (I suppose). It’s easy for me to get, they run their rebates once a year or so, seems to be “good” oil.
Yeah - as I burn through the last of my 3 brand stash - have tried to at least do back2back changes with the same stuff - sorta pick a brand/vehicle combo … For the two 8 quart engines - you have to dedicate 3 jugsAge old debate. I'm usually more of a purest as I don't like to mix oils, nor do I like to constantly switch back and forth. Does it matter? Meh probably not much. But each time you introduce a new chemistry into the engine, it has to lay down it's qualities and establish new tribofilms on the metal surfaces with it's own unique chemistry. Being most oils are compatible, it's not really an issue. I prefer to try and stay with one brand. I know we all get the urge to try new oils now and then and that is perfectly fine.
Nothing. Imagine all the engines that go to different service providers every time for an oil change with the lowest bidder providing a different oil each and every time.what’s wrong with switching every oil change?
But then again, formulations change quite often even within the same brand so I’m not too sure how much of the same consistent chemistry you’re really getting.Age old debate. I'm usually more of a purest as I don't like to mix oils, nor do I like to constantly switch back and forth. Does it matter? Meh probably not much. But each time you introduce a new chemistry into the engine, it has to lay down it's qualities and establish new tribofilms on the metal surfaces with it's own unique chemistry. Being most oils are compatible, it's not really an issue. I prefer to try and stay with one brand. I know we all get the urge to try new oils now and then and that is perfectly fine.
Might depend on how you shopBut then again, formulations change quite often even within the same brand so I’m not too sure how much of the same consistent chemistry you’re really getting.
What Amsoil OE ? Signature? If you are going to change it once a year and only drive 3,000 miles it would be a waste and maybe even wrong to run Signature - though it's a great lubricant. If Mobil 1 5W30 and O.E. are the same price its really a toss up. If not just 15 bucks a year more spent on a well kept performance car is inconsequenial. - KenI'm sorry if this has been discussed - I searched and didn't come up with any solid answers. Search was bogged down with comparisons.
I just purchased a car (1996 Z28 w/39k miles) that has been running on Mobil 1 for it's entire life (since 1k miles). I put Amsoil in my other vehicles ...
Hmm...can you please explain that more (why it could be *wrong* to run signature)? I do run signature in my other car that is rarely driven (maybe 1,000 miles a year).What Amsoil OE ? Signature? If you are going to change it once a year and only drive 3,000 miles it would be a waste and maybe even wrong to run Signature - though it's a great lubricant. If Mobil 1 5W30 and O.E. are the same price its really a toss up. If not just 15 bucks a year more spent on a well kept performance car is inconsequenial. - Ken
They are extremely high detergent long drain oils. You could most like run them for three years without changing.Hmm...can you please explain that more (why it could be *wrong* to run signature)? I do run signature in my other car that is rarely driven (maybe 1,000 miles a year).
Price isn't really an issue. They're both weekend cars and only get an annual oil change.
Is that really true? I know the oil pressure typically takes a few seconds to build up, but all the contact surfaces in the engine are lubed.Then when starting an engine after an oil change you are "dry starting" the machine with a chance for accelerated wear.
1200 rpm start and cold run with new smog engines with 4" stroke and severe rod angularity loads the rod bigs a bit more than the old days of Four-Three motors.Is that really true? I know the oil pressure typically takes a few seconds to build up, but all the contact surfaces in the engine are lubed.
This.I reiterate, I would not run a boutique motor oil in any vehicle that is only driven 1k miles per year and changed once a year, you get no benefit whatsoever from using it. IMO stretching the change interval to two years is not the answer either, you would be better-off using M1 and changing it every year.
