I have a 01 Honda Prelude with a few leaks- oil pan, oil cooler base and potentially front main and/or balancer shafts (I haven't removed the timing cover to look yet). Oil pan and oil cooler are easy enough to replace, but the balancer shafts and front main seals are a huge pita and I'd like to avoid doing them if possible.
Valvoline Maxlife dino seems to have stopped or slowed the leaks down in the 1500 miles it's been in. So now I'm wondering what will happen if I switch to a regular synthetic without the high dose of seal conditioners high mileage oils have. Will the leaks return? All the oils I'm considering switching to are higher viscosity than what's been run in the engine so far (5w30). I'd like to use Mobil 1 0W-40, Rotella 5W-40 or GC for the HTHS visc. Will going to 40wt do just as well as the Valvoline MaxLife 5w30 in the leaks dept? The the other option I'm considering is Mobil 1 High Mileage 5w30. HTHS is slightly lower (but higher than any other High Mileage oil) but it's got the high Z and P and seal conditioners.
