Originally Posted By: randomhero439
Bump, im about at 2500 miles (halfway) into this Mobil 1 oil with a Purolator Classic filter. Since its the first synthetic oil fill, should i change the filter at the halfway mark? Classics are only $3, and the cleaners probably released alot of sludge and varnish and the filter might be full.
Change the filter? Yay or Nay
I would if you suspect the filter is filled. Then I would run to 5K and do another OC with Mobil 1. Cut the filter open and inspect for sludge. If OK then run out to 10K with one filter change at 5K.
