Sustina Product Data
Where's Caterham when we need 'em?
Originally Posted By: dailydriver
I still wish they would put an accurate HTHSV on that spec sheet though.
I agree but as pdarm pointed out the 0w50 spec's are way off anyway. Not picking on Sustina as other company PDSs are not very accurate either particularly for low volume heavier oil grades.
With all of the supposed low temperature benefits if this super high VI product, you would think they would make MRV and CCS available. The pour points are respectable but nothing special for a synthetic. Lower pour points generally correlate with better MRV and CCS performance.
Not necessarily, here are Petro-Canada Supreme Synthetic 0w30 SN & SM numbers...
Code:
0w30SN 0w30SM
PP -48 -45
CCV 5920@-35 5524@-35
MRV 24800@-40 14204@-40
Notice the use of the word "generally", which does not mean always. There are more examples of lower pour points correlating with lower CCS and MRV than the converse.
And Red Line 0W-XX oils have a PP of -76F although their MRV and CCS spec's are anything but impressive. RL is not an oil one would really consider for extreme cold performance.
So "generally" doesn't count if you're actually choosing an oil because you're going to be starting at -40 degrees; you what to know actual performance and only CCS and MRV will tell you that.
There are more examples of lower pour points correlating with lower CCS and MRV than the converse. What are the "anything but impressive" MRV specifications for the Redline 0W-XX oils?
Since you have not responded to my query regarding the "anything but stellar" MRV data for Redline 0W-XX oils, I will provide them for you:
0W-20: 14,000@ -40c
0W-30: 14,800@ -40c
0W-40: 15,500@ -40c
For comparison, Mobil 1 0W-40 has MRV of 31,000@ -40c, Mobil 1 0w30 has a MRV of 13,250@ -40c, Pennzoil Platinum 0W-20 has a MRV of 17,700@ -40, Mobil 1 0W-20 has a MRV of 9200@ -40c.
Your contention that Redline 0W-XX "MRV and CCS spec's are anything but impressive. RL is not an oil one would really consider for extreme cold performance." is pure nonsense. Mobil 1 0W-20 is clearly a standout in extreme cold, but all of the Redline 0W weights would be excellent in extreme cold. In the 0W-40 weight, it is no contest. BTW, the pour point for Mobil 1 0W-40 is quite a bit higher as well. As it's pour point has gone up through formulation changes, so has it's MRV values. The folks at Redline are awaiting your mea culpa.
0W-20: 14,000@ -40c
0W-30: 14,800@ -40c
0W-40: 15,500@ -40c
Here are the MRV spec's I got from Dave at RL last year that have been sited on this form before:
0W-20 27,000cP
0W-30 28,000cP
0W-40 30,000cP
And Red Line 0W-XX oils have a PP of -76F although their MRV and CCS spec's are anything but impressive. Red Line is not an oil one would really consider for extreme cold performance.
BTW, for "extreme cold performance", Red Line 0W-XX oils are the ONLY ones I know of that would still be a liquid in Arctic and interior Alaska winters where temperatures can drop below -60 F. Everything else out there would become a semi-solid without a pan heater and even that would not prevent solidifying in the rest of the motor. Thus, "PP spec's are best ignored" should be ignored for extreme cold conditions.
