I read an article the other day about how quickly carbon dioxide levels can climb in a car when recirculating is turned on. Higher levels can lead to headaches, drowsiness, fatigue, and more. Especially not good when on long trips.
My wife and I regularly drive to Wisconsin, driving 18 hours straight through. She's about to embark on a 5k miles' trip on her own, So I bought
this CO/CO2 monitor off Amazon. Part of the display flashes green when the CO2 level is less than 700ppm, flash yellow when between 700-1500ppm, and flash red and sound an alarm when over 1500ppm.
Playing with it Testing yesterday in my closed-door home office, the CO2 level was close to 1200ppm, so I opened my window and it started dropping some, but stayed above 900. Thinking something must be wrong, I set it outside in the shade, where the level dropped and stayed just over 400, which I read was "normal" for being outside.
I opened all the windows in the house and the levels inside dropped to under 500 after an hour or so, but closed them after the outside temp climbed well past 80. This morning I came upstairs to my office and turned it on. It's currently flashing yellow with a reading of 918 to start my day. Unfortunately, it's still warm outside, so not opening the windows, yet.
She will be taking the monitor with her (I hope she uses it). We've talked about switching off the recirculate once the car cools off to have some fresh air.
I'd never thought about CO2 levels being so high in our home, but here in central Texas, it stays closed up most of the time with the A/C on.
We are constantly warned about, CO levels, but have you checked the CO2 levels where you work, live, and drive?
