Check your PCV valve and use OEM or Motorcraft oil filters.
As for oil, you may just want to go with name brand 30 weight conventional oil that burns clean since you're burning it anyway. Just do more frequent OCI's (3-5k miles).
Mazda RX rotary engines inject oil in the rotary and most owners use conventional oil that burns at lower temps and leaves very little residues to gum up the plugs.
