Supertech ST16 cut open
Indiana
Enjoy the pictures guys. Happy weekend.
Champion part numbers
Looks like a WIX base plate to me.
WIX combo ADBV/ bypass. They had a smaller ST9688, which was sized like the 7317 ironically, that had the WIX spring bypass.
Originally Posted By: Run
Looks like a Proselect. Wix number if I remember correctly is 1085.
Yeah, 1085 is correct. 21085 for a Proselect.
I was hoping to be the first one to post one of these. T.T
Sadly our Wal-mart doesn't have them in yet. They still have a fairly healthy selection of purolators on the rack.
Napa PS 21085, Silver 31085. MicroGard MGL51085. All would look very similar or same and use a combo valve.
The Wix/Napa Gold 5/1085 applications use silicone adbv and Wix's tradition metal thread end bypass.
Like the MGL, NPS and Silver line, some use a combo valve, however some applications use Wix's traditional metal coil spring thread end bypass. The MGL 51393 is an example of the latter.
Is that combo valve solid rubber? Between this and the other thread with an a/c delco ecore fram combinator I have no idea what is going on. They got the pleats nice by the seam, so it can be done.
The only time I ever had lifter clacking(caused by an oil filter) was with a Super Tech filter about 9 years ago on a 4.2 Ford truck engine. This started about 2K into an OC. I pulled the Super Tech off after 5-9 days of cold engine clacking, and installed a MC. Problem solved, so I have used MC filters ever since.
I stopped by a wal mart here in nj today but they still had the old White filters they can't seem to get rid of on the bottom shelf collecting dust on clearance, I was going to buy a couple of the new super techs to cut open just to see what they look like but you beat me to it. They seem to look good for $2.84
Much better than the ones that tear all the time. If i see them at wal mart i will pick up a couple and ask car 51 to post the pictures for me. In the past Wix always made good oil filters.. I was hoping to see the oil holes in the center tube i hope they stay large and not change to the small slits. If they keep making filters like the one in the picture and keep the price low they will be great sellers..
I hope they make an ST8316. The interesting filter will be ST7317, a cross to Wix's 51356 (because Wix also makes a 57356 with a slightly different base plate).
Also, the only ST I saw on the shelf was the ST5, but it had a proudly made in USA flag on it. But many of Wix's filters are Mexican, like the 51334 and 51356 sizes. Fram and Purolator make all their spin-on cans in the US.
I was going to pick one up to cut and post, but my Walmart doesn't have them yet either.
I might use one of these every once in a while for certain cars.
The pics mrsilv posted looked good to me. These do not. The pleats look too flat. Makes me think they are like wafers/crackers instead of like sandwich bread. I consider the same criteria on air filters too. It just seems it will work better when the end of the pleats are rounded instead of flattened.
I've always thought the flat pleats went along with paper media.
If you're wanting the round sandwhich bread, I recomend synthetic media.
If the ST 7317 is going to spec'd for use in Honda vehicles and others (as I expect), it will have/use the newer 57356 base plate design. IMO, Wix wouldn't use the now superseded 51356 baseplate design, because the change to the newer 57356 was made to improve the attachment to the engine block. And as I believe the new ST to be basically the O'R MicroGard filter line link shows what the ST7317 will look like.
http://www.oreillyauto.com/site/c/detail...9&ppt=C0023 Along the same line, if the full O'R MGL line is used, the ST8316 will be the same as the current MGL51315 also found on the O'R website. If the previous Classic line sold at Walmart included the Puro equivalent 'seems' like the new ST line would too.
Quote:
Also, the only ST I saw on the shelf was the ST5, but it had a proudly made in USA flag on it. But many of Wix's filters are Mexican like the 51334....
Yep, 'some' Wix spin on filters are made in Mexico. But having personally used the Napa Gold 1334 a couple times and posted pics, I experienced no drop off in quality compared to the US made Napa Gold 7356 and 1348 I've used.
However, if a coo of Mexico bothers one, just have to use an alternative brand, there's many. But for example, for those driving/owning a Ford vehicle made in Hermosillo, or a Kia/Hyundai made in S Korea, et al., I wouldn't think that would be an issue.
Definitely a Wix jobber type filter as mentioned. I have found them to work well and have good construction.
Only downside if you can call it that, is efficiency. Straight paper cellulose and likely around 70-80 percent at 20 microns. Don't know if it really matters much, but another 75 cents will jump you to 95% which may be a better buy for those who care about such things.
I certainly don't lose any sleep using one of these though.
Thanks for the cut and post!
Originally Posted By: KCJeep
Only downside if you can call it that, is efficiency. Straight paper cellulose and likely around 70-80 percent at 20 microns. Don't know if it really matters much...
I guess for under $3 you can't have it all. Although I'd rather have 90%+ efficiency, I plan on using one once they show up at my local Walmart.
Another 75 cents for what filter??
Im glad wal mart went with Wix i just hope that Wix stays a good quality filter and mann does Not decide to put those super small oil holes in the center tube and cut corners. Wix always used to be a great filter but they were bought by another company so lets see what happens.
If you remember, Mann+Hummel purchased Wix a while back.
It's a good marketing move to bring a private label Wix-built filter to Walmart.
