Thanks for all the responses.
I just spent around three and a half hours trying to remove the media from each filter without damage. I think that I was mostly successful.
The media from the WIX has a surface area of ~67.0 square inches (~432.5 cm^2), and the media from the FRAM has a surface area of ~83.4 square inches (~538.1 cm^2).
This is what the FRAM looked like after removing the end caps.
The adhesive on the FRAM was fairly easy to remove once the steel was gone.
The adhesive on the WIX was strong enough and elastic enough that I was afraid to attempt to remove it before taking this picture.
Lots of adhesive on the WIX...
Most, if not all, of the grooves in the adhesive were caused while removing the steel end cap. The adhesive itself tore and was still stuck to the end cap.
Front side of the media from the FRAM after removing it from the center tube.
Back side of the FRAM's media.
Front side of the WIX.
Back side of the WIX.
FRAM on the left and WIX on the right.
The backing mesh designs between the FRAM (left) and WIX are completely different.
The media from the FRAM (top) is longer and taller than the media from the WIX. The media from the WIX wouldn't sit as very flat on the floor, but you get the idea.
These are the three different layers from the FRAM. The outer layer is on the far left.
This is a closeup of the outer (left) and inner layers of filter media from the FRAM.
Closeup of the backing material from the FRAM. I'm not sure if it's stainless or if it has some sort of coating.
These are the two layers from the WIX.
Closeup of the WIX's filter media.
The mesh on the WIX is coated, presumably to hold the metal wires in place and to prevent corrosion during storage.
