At lunch time today I wandered over to Walmart to check out the oil and filters, is there any other reason to be there
? Anyway, the new Ecore SuperTech oil filters seem smaller than the previous Super Tech filters of the same number. For example the Super Tech2 is only about 1/2 the size of the equivalent Motorcraft FL-820S. Heck it's even smaller than the Fram equivalent. Which again is smaller than the Motorcraft FL-820S. I wonder if the area of filtering element area is also reduced from the previous larger can
? The same held true for the Super Tech8A, Motorcraft's FL-1A's equivalent and the Super Tech16, Motorcraft's FL-200 equivalent.
Whimsey
Whimsey
